RV Recalls 12-8-2025
The National Highway Traffic Safety Administration (NHTSA) has issued the following recalls.
FORETRAVEL, INC.
Incorrect Weld May Cause Seat Failure
A loose or detached seat assembly may not restrain the occupant as intended, increasing the injury risk during a crash.
Potential Number of Units Affected: 7
Foretravel is recalling certain 2020-2022 Realm and 2022 Realm 450 vehicles. The pedestal mounting plate may have been improperly welded, causing the plate to separate and the seat assembly to loosen or detach.
Dealers will inspect for a missing weld and replace the pedestal seat, as necessary, free of charge. Owner notification letters were mailed Dec. 2. Owners may contact Foretravel customer service at 800-955-6226.
NEWELL COACH CORP.
A loose or detached seat assembly may not restrain the occupants as intended, increasing the injury risk during a crash.
Potential Number of Units Affected: 3
Newell is recalling certain 2022 P50 coaches. The pedestal mounting plate may have been improperly welded, causing the plate to separate and the seat assembly to loosen or detach.
Newell will inspect for a missing weld and replace the pedestal seat, as necessary, free of charge. Owner notification letters were mailed Dec. 2. Owners may contact Newell customer service at 888-363-9355.
PLEASANT VALLEY TEARDROP TRAILERS LLC
Incorrect Weight Listed on CCC and Tire and Loading Information Labels
The trailer may be unintentionally overloaded after referencing incorrect information, increasing the crash risk.
Potential Number of Units Affected: 207
Pleasant Valley is recalling certain 2025-2026 nuCamp TAG, TAB 320, TAB 360 and TAB 400 trailers. The incorrect weight may have been listed on the cargo carrying capacity and tire and loading information labels.
Dealers will replace the labels, free of charge. Owner notification letters were mailed Nov. 14. Owners may contact Pleasant Valley customer service at 330-852-4811, ext. 834.
TIFFIN MOTORHOMES
Incorrect Cargo Carrying Capacity on OCCC Label
An overloaded vehicle can cause a loss of control, increasing the crash risk.
Potential Number of Units Affected: 8
Tiffin is recalling certain 2026 Open Trail motorhomes. The occupant and cargo carrying capacity label may have the incorrect cargo carrying capacity information, which can result in an overloaded vehicle.
Tiffin will mail corrected labels, free of charge. Owner notification letters are expected to be mailed Jan. 16, 2026. Owners may contact Tiffin customer service at 256-356-8661. Tiffin’s number for this recall is WAY-105.
Richard R. and Brenda S. have reacted to this post.
Richard R.Brenda S.
Thank you, you two.
Richard R. and Craig P. have reacted to this post.
Richard R.Craig P.
