RV Recalls 5-12-2025
The National Highway Traffic Safety Administration (NHTSA) has issued the following RV recalls:
BRINKLEY RV
Removable Steps May Detach While In Use
Steps that detach while in use increase the injury risk.
Potential Number of Units Affected: 1,607
Brinkley is recalling certain 2024-2025 Model G and Model Z fifth wheel travel trailers, equipped with a removable step assembly. The clip-on bracket mounting bolts may come loose, enabling the steps to detach.
Dealers will replace the clip-on bracket as necessary, free of charge. Owner notification letters are expected to be mailed May 7, 2025. Owners may contact Brinkley customer service at 1-574-501-4280. Brinkley’s number for this recall is REC-2502.
FOREST RIVER, INC.
Incorrectly Wired Solar Controller
Wiring without circuit protection may become damaged and short circuit, increasing the fire risk.
Potential Number of Units Affected: 1,167
Forest River is recalling certain 2025 Campsite Reserve travel trailers. The solar controller may be wired incorrectly without overcurrent circuit protection.
Dealers will rewire the solar controller power wire, free of charge. Owner notification letters are expected to be mailed June 11, 2025. Owners may contact Forest River customer service at 1-260-499-2100. Forest River’s number for this recall is 99-1926.
GRAND DESIGN RV, LLC
Potential Number of Units Affected: 121
Grand Design is recalling certain 2024-2025 Momentum 320G, 325G, 344M, 250G, 351MS, 381MS, 392M, 395MS, 397THS, 398M, 399TH, 410TH, 414M, and 415G toy haulers, equipped with a removable step assembly. The clip-on bracket mounting bolts may come loose, enabling the steps to detach.
Dealers will inspect the clip-on bracket and make repairs as necessary, free of charge. Owner notification letters are expected to be mailed May 22, 2025. Owners may contact Grand Design customer service at 1-574-825-9679. Grand Design’s number for this recall is 910050.
JAYCO, INC.
Kitchen Electrical Outlet Missing GFCI Protection
A lack of proper circuit protection increases the electric shock and injury risk.
Potential Number of Units Affected: 65
Jayco is recalling certain 2025 Entegra Launch and Jayco Terrain motorhomes. An incorrect standard outlet was installed in the kitchen instead of a GFCI-protected outlet.
Dealers will replace the non-GFCI breaker with a GFCI breaker at the load center for the proper circuit protection at the kitchen outlet, free of charge. Owner notification letters are expected to be mailed June 6, 2025. Owners may contact Jayco customer service at 1-800-283-8267. Jayco’s number for this recall is 9903629.
KEYSTONE RV CO.
Struts Inadequate to Support Fold-Down Patio
The operator may be unable to handle the patio’s weight, increasing the injury risk.
Potential Number of Units Affected: 70
Keystone is recalling certain 2025 Kodiak 2900FKSP and 308BHSL travel trailers. The struts may not support enough of the fold-down patio’s weight while being raised or lowered.
Dealers will affix a warning label, install bolts, and replace the struts, free of charge. Owner notification letters are expected to be mailed June 22, 2025. Owners may contact Keystone customer service at 1-866-425-4369. Keystone’s number for this recall is 25-465.
K.Z., INC
Potential Number of Units Affected: 45
KZ RV is recalling certain 2025 Durango Gold fifth wheels, equipped with a removable step assembly. The clip-on bracket mounting bolts may come loose, enabling the steps to detach.
Dealers will replace the clip-on bracket, free of charge. Owner notification letters are expected to be mailed July 5, 2025. Owners may contact KZRV customer service at 1-800-768-4016 ext. 154 or 153.
Richard R., Brenda S. and Tink H. have reacted to this post.
Richard R.Brenda S.Tink H.
Guess it’s getting worse, looks like will be building an alternative one ourselves for back up like Alan.
Alan K., Richard R. and 2 other users have reacted to this post.
Alan K.Richard R.Craig P.Tink H.
