RV Recalls 2-17-2025
Quote from Craig P. on 2025-02-17, 8:30 pmThe National Highway Traffic Safety Administration (NHTSA) has issued the following 2025 RV recalls:
GRAND DESIGN RV, LLC
Interior Step Tread Can Break
A broken step increases the injury risk.
Potential Number of Units Affected: 21,982
Grand Design is recalling certain 2019-2024 Grand Design Solitude fifth wheel trailers. The step tread joints may be unsupported, causing the tread to break.
The remedy program is currently under development. Owner notification letters are expected to be mailed May 1. Owners may contact Grand Design customer service at 574-825-9679. Grand Design’s number for this recall is 910048.
JAYCO, INC.
Water Tank Support Brackets May Damage Fuel Tank
A fuel leak in the presence of an ignition source increases the fire risk.
Potential Number of Units Affected: 1,106
Jayco is recalling certain 2021-2025 Entegra Coach Launch, 2022 Launch Le, 2021-2025 Jayco Terrain and 2022 Terrain Le RVs. The grey water tank support brackets may contact and damage the fuel tank, causing a leak.
Dealers will replace the support brackets, free of charge. Owner notification letters are expected to be mailed March 28. Owners may contact Jayco customer service at 800-283-8267. Jayco’s number for this recall is 9903619.
STORYTELLER OVERLAND
Improperly Welded Seat Assembly
A loose or detached seat assembly increases the injury risk.
Potential Number of Units Affected: 120
Storyteller Overland is recalling certain 2024-2025 Mode XO vehicles. The seat assembly’s floor mounting system may be improperly welded, which can cause the seat assembly to loosen or detach. As such, these vehicles fail to comply with the requirements of FMVSS No. 207, “Seating Systems.”
The remedy is currently under development. Owner notification letters are expected to be mailed April 2. Owners may contact Storyteller customer service at 888-999-7442.
WINNEBAGO INDUSTRIES, INC.
Propane Tanks May Detach
A detached tank can become a road hazard, increasing the crash risk.
Potential Number of Units Affected: 696
Winnebago is recalling certain 2025 Minnie Winnie, Navion, Porto, Spirit, View and Vita RVs. The LP tank mounting bracket fasteners may have been improperly tightened, causing the tank to detach.
Dealers will inspect and correctly tighten the LP tank mounting assembly, free of charge. Owner notification letters are expected to be mailed April 10. Owners may call Winnebago customer service at 800-537-1885. Winnebago’s number for this recall is 195.
JAYCO, INC.
