RV Recalls 11-25-2024
RV Recalls November 25, 2024
The National Highway Traffic Safety Administration (NHTSA) has issued the following 2024 RV recalls:
GRAND DESIGN RV, LLC
Cracked LP Gas Quick Disconnect Fitting Can Leak
A gas leak in the presence of an ignition source can increase the fire risk.
Potential Number of Units Affected: 30,435
Grand Design is recalling certain 2022 Imagine, Momentum, Reflection, Solitude and Transcend travel trailers. The quick disconnect fittings in the LP gas system may be cracked, causing a gas leak.
Dealers will inspect and replace quick disconnects as necessary, free of charge. Owner notification letters are expected to be mailed Dec. 6. Owners may contact Grand Design customer service at 574-825-9679. Grand Design’s number for this recall is 910045. This recall supersedes Grand Design RV recall 22V308.
Battery Warming Pad Can Short
An electrical short increases the fire risk.
Potential Number of Units Affected: 48
Grand Design is recalling certain 2025 Lineage 25FW motorhomes. The battery warming pad was installed incorrectly, which can damage internal wiring and cause an electrical short.
Dealers will replace the battery warming pad, free of charge. Owner notification letters are expected to be mailed Dec. 6. Owners may contact Grand Design customer service at 574-825-9679. Grand Design’s number for this recall is 910046.
OLIVER TRAVEL TRAILERS, INC.
Loose Water Heater Burner Assembly May Start Fire
A misdirected flame increases the risk of fire or burn injury.
Potential Number of Units Affected: 784
Oliver Travel Trailers is recalling certain 2016-2024 Elite I and Elite II travel trailers equipped with a Truma Aqua Go water heater with burner assembly, part No. 77000-90400. The water heater burner bracket assembly may become loose, causing wiring damage and the flame to be misdirected.
Dealers will replace the water heater burner assembly, free of charge. Owner notification letters are expected to be mailed Dec. 3. Owners may contact Oliver customer service at 888-526-3978.
Richard R., Brenda S. and Tink H. have reacted to this post.
Richard R.Brenda S.Tink H.
