RV Recalls 6-1-2026
The National Highway Traffic Safety Administration (NHTSA) has issued the following recalls:
Alliance RV, LLC
Battery Heating Pad May Overheat
The heating pad may overheat in the battery compartment, increasing crash risk.
Potential Number of Units Affected: 2785
Alliance RV is recalling certain 2022-2025 Valor and Paradigm recreational trailers. The heating pad may not be appropriate for lithium battery applications.
Dealers will replace the heating pads, free of charge. Owner notification letters are expected to be mailed May. Owners may contact Alliance customer service at 1-574-218-7165. Vehicle Identification Numbers involved in this recall will be searchable on NHTSA.gov beginning May 29.
Incorrectly Tightened Shock Bolts
Broken shock retainer bolt heads and washers may detach and become a road hazard for other vehicles, increasing crash risk.
Potential Number of Units Affected: 2536
Alliance RV is recalling certain 2025-2027 Paradigm recreational trailers equipped with certain Curt Touring Coil Suspensions. The shock bolts may have been incorrectly tightened.
Dealers will replace the shock bolts, free of charge. Owner notification letters are expected to be mailed May. Owners may contact Alliance customer service at 1-574-218-7165.
Brinkley RV
Potential Number of Units Affected: 6061
Brinkley RV is recalling certain 2025-2026 Model Z trailers. The shock bolts may have been incorrectly tightened.
Dealers will replace the shock bolts, free of charge. Owner notification letters are expected to be mailed June 2. Owners may contact Brinkley’s customer service at 1-574-501-4280. Brinkley’s number for this recall is REC-2602. Vehicle Identification Numbers involved in this recall will be searchable on NHTSA.gov beginning May 28.
Ember RVs, Inc.
Improperly Tightened Shock Bolts
Potential Number of Units Affected: 143
Ember RVs is recalling certain 2026-2027 Touring Edition recreational trailers, equipped with certain Curt Touring Coil Suspensions. The shock bolts may have been incorrectly tightened.
Dealers will replace the shock bolts, free of charge. Owner notification letters are expected to be mailed June 1. Owners may contact Ember customer service at 1-844-732-4204.
Forest River, Inc.
Potential Number of Units Affected: 200
Forest River, Inc. is recalling certain 2026 Riverstone, Cedar Creek, and 2024 R-Pod recreational trailers equipped with Curt Touring Coil Suspensions. The shock bolts may have been incorrectly tightened.
Dealers will replace the shock bolts, free of charge. Owner notification letters are expected to be mailed June 1. Owners may contact Cedar Creek customer service at 1-260-593-4000, R-Pod customer service at 1-574-642-3119, and Riverstone customer service at 1-260-593-4028. Forest River’s number for this recall is 51-062.
Keystone RV Company
Loose shock bolts may cause a loss of vehicle stability, increasing crash risk.
Potential Number of Units Affected: 773
Keystone is recalling certain 2024 Cougar, 2025-2026 Alpine, 2026 Montana, and Walkabout recreational trailers. The shock bolts may have been incorrectly tightened.
Dealers will replace the shock bolts, free of charge. Owner notification letters are expected to be mailed June 1. Owners may contact Keystone customer service at 1-866-425-4369. Keystone’s number for this recall is 26-483.
K.Z., Inc.
Potential Number of Units Affected: 677
K.Z., Inc. is recalling certain 2026 Durango recreational trailers equipped with certain Curt Touring Coil Suspensions. The shock bolts may have been incorrectly tightened.
K.Z. will replace the shock bolts, free of charge. Owner notification letters are expected to be mailed May. Owners may contact K.Z. customer service at 1-800-768-4016 ext. 154 or 153. K.Z.’s number for this recall is KZ-2026-01.
Shyft Group
Unintended Brake Light Illumination/FMVSS 108
Brake lights that remain on may fail to alert other vehicles of the driver’s intention, increasing crash risk.
Potential Number of Units Affected: 836
Shyft Group is recalling certain 2025 Spartan RV Chassis K1, 2024-2026 RV Chassis K2, RV Chassis K3, and 2025-2027 RV Chassis K4 vehicles. The exterior brake lights may remain illuminated when the driver is not applying the brakes. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 108, “Lamps, Reflective Devices, and Associated Equipment.”
Shyft will replace the pressure switch, free of charge. Owner notification letters are expected to be mailed June 5. Owners may contact Shyft customer service at 1-800-237-7806. Shyft’s number for this recall is 26-05.
Tiffin Motorhomes, Inc.
Park Outside: Fuel Tank Puncture May Cause Fire
A fuel leak in the presence of an ignition source increases fire risk.
Potential Number of Units Affected: 392
Tiffin Motorhomes is recalling certain 2025-2026 GT1, 2026 GH2, and GH1 motorhomes. A screw may have punctured the fuel tank during manufacturing, causing a fuel leak.
Owners are advised to park outside and away from structures until the remedy is completed. Dealers will inspect and replace the fuel tank as necessary, free of charge. Owner notification letters are expected to be mailed July 24. Owners may contact Tiffin customer service at 1-256-356-8661. Tiffin’s number for this recall is TIF-148.
Incorrectly Colored Cargo Carrying Capacity Label/FMVSS 120
The incorrect label color may make it difficult for the operator to locate the loading or tire pressure information, increasing crash risk.
Potential Number of Units Affected: 160
Tiffin Motorhomes is recalling certain 2026-2027 Open Trail, Wayfarer, and 2026 Midas recreational vehicles. The Cargo Carrying Capacity label may have been incorrectly printed on a white label. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 120, “Wheels and Rims-Other Than Passenger Cars.”
Dealers will replace the label, free of charge. Owner notification letters are expected to be mailed July 24. Owners may contact Tiffin customer service at 1-256-356-8661. Tiffin’s number for this recall is WAY-107.
Brenda S. has reacted to this post.
Brenda S.
